FiTmEnt....... 19's. Help?!
Old 07-30-09, 08:02 AM
upstateGS4
upstateGS4's Avatar
Default FiTmEnt....... 19's. Help?!
yo kids.
19x9.5 & 19x10.5, +23 all around.... 2nd gen gs430. front fender tabs are rolled, rear fender inners shaved flat...no pull yet...air suspension. will i have a problem with fitment and will that look alright?
tire size/brand recommendation? not looking for a crazy stretch.
Old 07-30-09, 08:50 AM
dboyz85
dboyz85's Avatar
Well my cars the exact same as yours with air, Im running 19X9 and 19X10 with +22 all around on falkens 452's 225/35/19 and 245/35/19. I also add a 10mm spacer in front and 5 mm spacer in rear with -1 camber. I dont have a problem with rubbing when Im raised up and when I bag it, it sit perfect. Hope that helps.
Old 07-30-09, 07:45 PM
mex lex
mex lex's Avatar
It will be spot on, go for it!
Old 07-31-09, 03:42 AM
[ant]
[ant]'s Avatar
225/35 front 245/35 rear, its not crazy but its aggressive as in rim protrudes and wathc your pressures regularly.
theyll look good...
Old 07-31-09, 08:22 AM
Rides Low
Former Sponsor
Rides Low's Avatar
dude, what are you doing with those 20's. I know for you to downsize, you must be doing something sick
Old 07-31-09, 08:11 PM
upstateGS4
upstateGS4's Avatar
to everyone else, thanks for the input and quick responses
Old 09-03-09, 05:44 PM
VNN326
VNN326's Avatar
since your on air i would run a 10mm spacer all around it would fit go for a 225 35 in the front and 235 35 in the rear. perfect fit.
Old 09-03-09, 11:57 PM
VipDout
19x11.5 -51
VipDout's Avatar
I got a pull from hell and run a 19x10.5 -8 and bagged here's a quick shot
But If I let the car weight smash the tire I could easily look like this 30 psi rear
also see a pulled 19x10 -8 looking great too , hope that helps mang
Old 09-04-09, 05:05 PM
phillygs3
phillygs3's Avatar
I think you can go more aggressive , if your willing to pull some
Old 09-04-09, 05:12 PM
phillygs3
phillygs3's Avatar
He's talking about your spirit's
Old 09-21-09, 01:05 AM
isaacly
isaacly's Avatar
u got pics of your setup?
Old 09-22-09, 07:42 AM
BAP077
BAP077's Avatar
Default Front Tires/Wheels Question
Can someone tell me if 235/35/19's on 19x8 for front wheels, will rub? I know that there are posts/threads on this suibject but I need a quick response. Thanks.
Deathrow23
09-12-15 01:48 PM
candyeg
07-18-12 11:39 AM
vipsc400
SC- 1st Gen (1992-2000)
03-15-12 09:21 PM
wum
Wheels, Tires & Brakes Forum
12-25-11 10:41 AM
cro126
01-17-10 09:05 PM
Quick Reply: FiTmEnt....... 19's. Help?!
