Air suspension woes.
Old 09-21-09, 12:06 AM
isaacly
isaacly's Avatar
jb weld it.
Old 11-02-09, 10:09 PM
I8ABMR
I8ABMR's Avatar
gotta be a bit slick to have an air system. Got to be good with the quick fixes
Old 11-04-09, 11:04 PM
airmax
airmax's Avatar
i know this is a late response, but, who did your air install?
Old 11-04-09, 11:27 PM
radicalrev
radicalrev's Avatar
i am so screwed if this happens to me...*touch wood*
Old 11-05-09, 10:12 AM
IXI187IXI
IXI187IXI's Avatar
where are your valves mounted at? how did you manage to get a hole so close to the fitting?
hard lines are a good idea but they are pretty expensive, not to mention you'll need a pipe bender.
i had something similair happen on my old car. did notice the leader hose for the front back was rubbing on my tie rod and it managed to put a hole in the hose. thank god i was near a cvs. i grab duct tape, wrapped the hose and had to keep hitting the switch every minute to keep the car up but it worked to get me home lol.
Old 11-10-09, 09:25 PM
EN_VY
EN_VY's Avatar
I did
My valves are behind the seats, I have the tank in the trunk and I guess, this is just a guess: That the remote wire from the amp(which was not completely protected) made contact with the wire from the pressure switch(also wasnt protected) which sent a spark to the hose.. Thats the only reasonable explanation I find..
Anyways, Its all a learning process I guess. I have gone through other crap since I posted this, but I have been gaining experience as well. I love my suspension by the way! The car is a looker when its rolling slammed
Old 11-25-09, 02:15 AM
VipDout
19x11.5 -51
VipDout's Avatar
yea know , If I leak air and am flushed , Nothin can help me hahaha
Old 11-25-09, 08:39 PM
Durrby
Durrby's Avatar
Try having this happen while your driving...Not once but twice. This is a prime example of you get what you pay for. This is the result of an "airbagit.com" kit. I was told the back and forth motion of making turns caused the bolt to unscrew itself from the strut but stay in place within the strut mount (not pictured). I have no idea why it's designed this way but it was scary as hell driving on a winding road at about 40mph or so and then pop you lose air in one corner and come to find out the strut isn't even secured to the car. I definitely did some damage because the corner now looks to be really cambered so I don't know if I bent or snapped something. It was also like pulling teeth trying to get a replacement air strut.
Old 11-28-09, 12:57 AM
VipDout
19x11.5 -51
VipDout's Avatar
I can top all of this though ,
have your airbag blow out while 80 on the freeway , my old set up airride tech . not weighted for the weight of the car . Custom Fab. (fail)
3 times total fails..... can you imagine why I know my airset up really good ?
ReeM
11-27-16 11:21 PM
EN_VY
Suspension and Brakes
26
10-07-09 09:08 PM
bonafyd
VIP Style
20
04-08-09 10:21 AM
dRo15
08-11-08 07:13 PM
o2 jockey
Suspension
02-22-08 10:48 AM
Quick Reply: Air suspension woes.
