ways to bleed the air suspension tank?
Old 09-09-09, 11:22 AM
vwynn
vwynn's Avatar
Default ways to bleed the air suspension tank?
how do you guys bleed the tank?
my bleed port is located in the back of the tank but i cant get to it unless i unbolt my whole setup..
trying to figure out another way to bleed it.
Old 09-09-09, 11:54 AM
iSuxeL
iSuxeL's Avatar
I'm guessing the bottom of your tank doesn't have a release? From the looks of the Ksport kit I don't think there is another way. Are you trying to let out the moisture?
Old 09-09-09, 02:55 PM
vwynn
vwynn's Avatar
yea pretty much. i want to drain the tank of moisture at least once a month or once every other month.
Old 09-09-09, 03:59 PM
V8_Aristo
Bippu
V8_Aristo's Avatar
Add a water trap between the tank and the compressor. This is minimize the moisture getting in your tank, but will not completely eliminate it. I have a drain valve, but cannot access it, so I still take out the tank once a year (even with a water trap).
Old 09-09-09, 05:21 PM
iSuxeL
iSuxeL's Avatar
I would recommend getting a different tank with a release valve at the bottom like mines. Those water traps are pointless IMO. I've ran my system without them since I had them.
Old 09-09-09, 07:05 PM
phillygs3
phillygs3's Avatar
I wouldnt say pointless , my traps catch alot of water
Old 09-09-09, 07:56 PM
iSuxeL
iSuxeL's Avatar
I guess I worded that wrong. It does trap water/moisture don't get me wrong. But the way I see it, you still have to drain the tanks. So as long as I do that every month I'll be ok
Old 09-09-09, 08:25 PM
DriftGirl
DriftGirl's Avatar
think grasshoppers
one can always put a couple feet of air-line with a valve on teh end to release the air
you can then have a release anyplace you'd like
Old 09-09-09, 08:34 PM
skperformance
skperformance's Avatar
Get a trap it works better than anything .
I drain it every 2 weeks for 5 seconds.
The tank every 3 months but it never gets moisture since i regularly dump the trap .
Old 09-09-09, 10:32 PM
vwynn
vwynn's Avatar
yea thought about that one as well. But i figure imma empty it anyways via drain.
my tank has the drain hole for it.. its just located behind the tank n at the bottom of the tank.. prob is.. theres no room for me to get back there unless i remove the whole tank which is a lot of work =[
Originally Posted by Emerald
think grasshoppers
Brilliant! hah thats what im thinking.. use it as a bleeder or use it to dust off stuff!!
when u drain for 5 secs is it hard to reconnect the plug?? especially with all that air rushing out?
Old 09-09-09, 11:24 PM
skperformance
No disconnecting anything when dumping the trap I have from IR .
It is a **** on the bottom of the trap where the water collects.
You turn the **** and it blows out the moisture collected with some air then you tighten it back up by hand. Real quick and easy.
You need to get one that is rated at 150-200 lbs max for air suspension in a car.\
About $20
Old 09-09-09, 11:26 PM
V8_Aristo
Bippu
V8_Aristo's Avatar
Remember, the water settles on the bottom. If you are planning to add a hose/line, make sure it's from the lowest point of the tank. Anything higher and you will just bleed out air and not the water.
Old 09-10-09, 08:39 AM
vwynn
vwynn's Avatar
yea its at the bottomish of the tankish.. ill draw a picture soon hah
Old 09-10-09, 08:52 AM
vwynn
vwynn's Avatar
About $20
Does brand matter? What do you personally use for your air tank?
Old 09-10-09, 09:51 AM
iSuxeL
iSuxeL's Avatar
That's what I've been trying to say LOL. There's absolutely no point in draining the tank if the release isn't at the bottom.
Quick Reply: ways to bleed the air suspension tank?
