Air runners or Ksport Air?????
#66
#67
Bringing this back too life cause I'm bout to make the plunge. Gonna re-do my entire ride paint and all and want to go on air. Would like to know the longevity of Ksport cause that's the kit I would like to get but also have some questions. Can you ride low on this kit. Is it pretty much a plug and play. And can some one direct me to where I can get it the cheapest. As far as instal I do all my DIY's. Thanks in advance for all responses to this.
#69
Beed riding on my kit since 2009
Yes you can. Long as you shorten the bags all the way. Also adding RCA's to your car helps a lot with riding with more pressure at a lower height.
Yes its a PNP kit. Install bags, run hoses to the rear, run power/accline to the rear, connect all the pluming and wiring, run controller wire to the front and youre gtg..
hit up the venders on the board.
answers in bold.
#72
forget both. I have friends that ran both setup, but the most reliable is the cup kit suspension. Just bought mine over the weekend from platinum vip
www.phantomsuspension.com use PMVIP25 for 25% off!!!
I am excited, will keep you guys updated..
#73
www.phantomsuspension.com use PMVIP for 25% off!!!
#74
hmmm i dont know about that bro. i have a airrunner system and a friend of mine has a cup kit i have had no problems he has had like 2 or 3 problems with his cup kit.
it could be the install or just luck but i love my airrunner with the accuair its perfect i cant ride slamed like a cup kit but im pretty low ill post a pic latter
#75
A simple air system for example
Uas bags
Coilovers- coilover springs
Lines/fitting
Switches
Tank
Compressor
manifold
what comes in a cup kit
