Rolling/shaving Ls430 guards...
Old 01-06-11, 03:12 PM
Dutchie101
Dutchie101's Avatar
Default Rolling/shaving Ls430 guards...
Heya.
Just wondering if some of you more knowledgeable folk can help me out..
As some of you know im looking at some wheels, just working out offsets, then ordering..
When rolling or shaving LS430 guards, i assume you remove that thin edge liner that goes along the radius of the arch? correct? will the larger liner still stay in place? Or do you leave this this 'edge' liner?
If anyone can give a short 'what to do with 430 liners' rundown that would be great..
Thanks in advance,
Pete
Old 01-06-11, 03:43 PM
DriftGirl
DriftGirl's Avatar
I always rsuggest to Rolling fenders. Shaving is cooh too, but if not sealed you run the risk of rust.
remove all liners and clips before using a fender roller. You may have to mod them a bit to reinstall but its not really a big deal....these are general rules to rolling fenders.
heatgun to warm up the area and try to prevent paint from cracking...and sealer just in case it does crack.
Find a friend who has done it before. Bodywork to repair arches on fenders is a major headache.
good luck!
Old 01-06-11, 07:13 PM
Dutchie101
Dutchie101's Avatar
Thanks DriftGirl,
Ive done rolling before on previous car, just havent encountered the extra little bits that the LS has..Seems like the rear flange trim is just rubber, so that should be easy to deal with. The front seems a little more effort is needed.
All good, ill get my body finisher to deal with it
Old 02-02-11, 04:44 PM
RAMPAGEsd
RAMPAGEsd's Avatar
dunno if you touched your fenders yet but LS430's have studs in the inside that hold the liner in place right above the wheel arch. might be a better idea to shave it down and coat it if you max clearance for your wheel setup.
Old 02-28-11, 01:49 AM
Dutchie101
Dutchie101's Avatar
Update:
Had the fronts rolled today. Perfect job and they guys didnt have to shave the liner tabs off the front.
Rears shave 5-7mm and slight roll.
Excellent work.
Old 03-06-11, 11:14 PM
notserp
notserp's Avatar
Originally Posted by Dutchie101
Update:
Excellent work.
any pics???
Old 03-07-11, 12:04 AM
Dutchie101
Dutchie101's Avatar
No pics of the inside of the guards sorry, but heres the car as it sits now, with the SS-Kit installed and Tanabe DF210's (total drop 55mm all round)
^my fav pic so far
Now to add 5mm spacer @ the front.
Old 03-07-11, 05:20 AM
Schnitz
Schnitz's Avatar
Coming along nicely.
A little bit lower all around and it's be perfect height. Time for Megans.....
Old 05-10-11, 01:31 PM
GSoup
GSoup's Avatar
Found my old pictures... Shaved...
- Remove the plastic piece.
- tape it up
- cut off lip
- grind/sand it down
- paint it to prevent rust
Ride height...
rich30769 (04-25-22)
ebxgsxr
Northeast
03-15-19 08:37 AM
FatBrian81
SC- 1st Gen (1992-2000)
04-04-11 03:21 PM
pvo
Wheels, Tires & Brakes Forum
07-06-06 09:07 AM
I6turbo
09-15-05 10:00 AM
Quick Reply: Rolling/shaving Ls430 guards...
