What am i doing wrong? Need some tire help
Old 02-05-12, 06:30 AM
m32
m32's Avatar
Default What am i doing wrong? Need some tire help
I have a 3 gs running 20x8.5 fronts on a 22mm offset on 225/35 and it's rubbing at full turn. Even with a full shave, it'll still touch the fender and the liner. I'm thinking my tires are oversized. Would running a thinner tire fix my issue? 225/30 or 215/35 on a 8.5? Appreciate your input. Thanks
Edwin
Old 02-06-12, 11:38 AM
mr3gs300
mr3gs300's Avatar
For a 20 inch tire youre gonna need to run either a 245/30/20 or a 245/35/20 for a lil cushion
Old 02-06-12, 04:09 PM
geeznuts
geeznuts's Avatar
225/30/20 will work but will be very thin. 245/30 might be better. Since there's no 215/35/20
Old 02-06-12, 04:20 PM
m32
m32's Avatar
I'm already rubbing with 225/35, wouldn't 245/30 make it even worse?
Edwin
Old 02-07-12, 01:25 PM
horent135
horent135's Avatar
For 8.5 you can do 215/35 or 40 to get extra cushion. I seen that does 195,but that might stretching too much.
Old 02-07-12, 11:19 PM
MIKU*SC3
MIKU*SC3's Avatar
Most likely smaller walls will do the trick,. Id say go for a 225 30.
But remember that different tire brands fit differently so i would probably stick with the same type of tire.
Old 02-08-12, 05:46 AM
Schnitz
Schnitz's Avatar
Best you can do is try. I'd say 215/35 is your best bet. Highest rate of success with that size tire on your setup. If you do have some room after that you can always get a larger tire next time around.
Old 02-10-12, 03:28 AM
Dutchie101
Dutchie101's Avatar
You can also heat and remould your liners too, obviously wont help the fender scrape, but should eliminate liner scrub.
Old 04-11-12, 06:40 PM
Platinum-VIP
Former Sponsor
Platinum-VIP's Avatar
smallest they make for a 20" tire is 225/30 unless you want to be a baller and get 215/30/20 from Toyo.
8.5 is a very hard size to stretch, sometimes 215/30 wont stretch decent enough on a 8.5
pictures of your car would help.
Old 04-11-12, 06:54 PM
Sffd103
Fire Slayer
Sffd103's Avatar
my boy is running a 225/30/20 on his fronts on his 3GS.
Old 04-12-12, 10:07 PM
gekae24
gekae24's Avatar
What about a 215 30 20 on a 20x9 rim or 20x9.5 how would that look?
Old 04-13-12, 06:44 AM
m32
m32's Avatar
Thanks for all your input guys. I thought about switching down to smaller sizes but decided to just raise the front a little and adjust the back accordingly. Although I would love the slammed look, the car being my daily to work is just not logical and professional.
Platinum, here are just a couple of shots after getting the fronts dialed in to where it clears everything
Edwin
Old 04-13-12, 12:02 PM
Mike1970
Mike1970's Avatar
i have a 3gs i was running 19 x 8.5 +32 and a 19 x10 +32 225/35/19 225/35/19 i had to roll and shave to get it to work. i was pretty low. even with a 215 in the front it rubbed
superdenso
09-03-16 12:30 AM
Languistic
05-23-12 10:37 AM
votru
Wheels, Tires & Brakes Forum
11-10-11 11:19 PM
lkapimp216
VIP Style
06-23-11 02:05 AM
spotxc
10-12-09 08:33 AM
Quick Reply: What am i doing wrong? Need some tire help
