JDM 3pc. wheels 18"
JDM 3pc. wheels 18"
JDM STICH Precious Spoke 3pc. wheels w/brand new tires
front = 18x8.5 with +41 offset
rear = 18x9.5 with +41 offset
tires are BRAND NEW falken azenis ST115
front = 235/40/18
rear = 265/35/18
some paint peel on one centercap and light curb rash so price is very reasonable.
PLEASE no lowballers.
i am asking $1700 for wheels and tires. they are already mounted and balanced.
i am selling because i decided to go with some new 19" amistads.
front = 235/40/18
rear = 265/35/18
brakes..
dunno. i just went out and measured on my car with stock calipers and there is 10mm of clearance. so if supra brakes are 10+ mm or larger than stock calipers, they will not work.
hope this helps.
hope this helps.
Re: brakes..
hope this helps.
hope this helps.
I bought some wheel spacers (I know...totally Ghetto) from www.summitracing.com for the time being until I come up with some different wheels. The wheel spacers are 8mm (5/16) and the wheels clear the calipers by 2mm (minimum safe distance).
So....I'm looking for new wheels with at least a 46 mm offset to clear the calipers.
Hope that helps.
Offset will not affect the clearance of a big brake upgrade. It's all about the disk (high, med. and low). I don't believe these will clear.
Beautiful wheels though.
If there isn't enough offset to the wheel....the backside of the wheel center will hit the outward facing component of the calipers.
It's common knowledge that you need at least 17" wheels to have enough diameter to clear TT calipers, but that's not what we are talking about here. We are talking about offset.
As I said before....38mm offset 17" wheels will fit OVER the calipers but once bolted down, don't clear the front side of the calipers with the back of the wheel face.
