another "will these fit on my sc" questions
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
I've found a set of Work Equips. The fronts are 8.5"(+35) offset and rears are 9.5 (+40) offset. Would these be able to fit an SC? Would they clear TT brakes?
thanks for any help.
Originally posted by ummagawd
its not so much the offset.... but rather the disc setup of the wheels
i.e. Volk uses an A, B ,C disc system (A being for big brake setups)
ummagawd is right, in order to clear supra TT brakes you will need a high disk setup. usuallly the bigger lip in front decreases the inside caliper clearance, but that rule is not set in stone.
SC3ooToy
Suspension and Brakes
13
11-22-05 12:53 PM
