Metal Hubcentric Rings
Brand new set of Metal Hub Centric Rings for 2nd Gen IS. These are not the Poly Carbon rings but made of metal which are much better quality than plastic/poly carbon rings and are made to a more exact, closer tolerance for a proper fitment. They won't crack, melt or break over time like plastic rings do.
Rings will fit the hub of the 2nd Gen IS and have a 60mm inside diameter and a 73mm outside diameter.
To check fitment, use a mic and measure the hub of your car and that will mach the inside diameter measurement, and measure the inside hole of your wheel and that will be the outside diameter measurement.
$18 for the set of 4 shipped to the lower 48.
![](https://www.clublexus.com/gallery/data/3453/medium/DSCF0314.JPG)
mryuen@usa.net
mryuen@usa.net
peterls
08-08-14 09:17 AM
GS1stgen
GS - 1st Gen (1993-1997)
05-02-07 05:57 PM
b1gredek
Wheels, Tires & Brakes Forum
06-06-05 10:11 AM
