lsportline - 3 piece wheels 20x9.5-20x9 cheap
#32
hey do u have pics of them on ur e-class? if so.. can u post or send to loopdiggakid@tmail.com thanks
-roger
-roger
#34
i am still confuse... if wheels are originally 114.3 how can you enlarge the holes to 112? 112<114.3??? so the wheels fit both benz and lexus now? is that even possible because i see only 5lugs holes on the wheels.
#35
#37
You enlarge the holes and would need a special nut to seat against the larger hole. If it is not done to exacting specs the wheel will vibrate badly from being off centered.As well as having to slowly torque each nut down in small increments to achieve even torque and seating.
#38
wheels was not re- drilled by me it was done by wheel shop professionally and i think the only way you will get a bad vibration is if you dont use proper hubrings.
the_ez_rhino
Wheels and Tires Classifieds
30
03-27-09 08:33 AM
