FS: ADR Decadence 19"
it depends on your drop. if you are stock height to approx 1.3" drop then you should be fine. if you have 1.5" or more, you might need to stretch tires or shave fenders to make it fit. for example for me, I am on agx+eibach drop which is approx 1.9" all around so for tires I would have to run 35f/30r profile tires and run a bit more negative camber to make it clear, but i wouldnt suggest running on 30 profile tires because that'll really mess up your rims in a short period of time driving around on bumpy california roads lol.. but i would suggest you to consult the official SC wheel+tire thread.
well...the car will be lowered in the future..prolly nothing more than an inch and a half or so with some coilovers. I plan on rolling the fenders with the Eastwood Fender Roller. Do you think that would be enough to make them clear with the 1.5" drop? I read the tire thread before hand and ive seen people running 10" in the rear but with around a +40 offset...i was hoping that the Eastwood Fender Roller could actually bring the fenders out a litte, as in make the fenders a little wider. what do you think?? Im interested in the rims BTW and im local.
20/25 offset on 19's is perfect.. you just need to stretch the tires a little bit and roll your fenders anywhere from .25-.5 inches.. and since you will be on a 1.5" drop you're good..
smokyis350
Wheels and Tires Classifieds
01-20-14 09:11 PM
VINCE9164
14
10-09-12 11:20 PM
RAMPAGEsd
06-22-09 02:40 PM
