FS: H&R Hubcentric 20mm spacer | Project Kics 15mm spacer w/ hub core | 3mm spacer
Master Thread Closer!!
- H&R Hubcentric 20mm spacer..........$110 shipped. You will need to install the longer studs onto your hub....this meanings removing your caliper, rotors, and oem studs.
- Project Kics 15mm spacer w/ hubcentric core (60.10 mm for Lexus).........$170 shipped. Comes with longer studs pressed into the spacer...so just mount directly onto the rotor top hat.
- 3mm spacer (universal fit)......$45 shipped.
Money orders preferred...if paypal, add 3.5%.
Pete
Pete
In regards to the 3mm spacer...there will be room on your hub's core for rings to still mount.
for those of you interested in the kics 15mm spacers with the built in studs, keep in mind the wheels you will be using these spacers with must have the "cutouts" on the back of the wheel in between each mounting hole because your stock studs will stick out past this spacer when its mounted.. if you have a flat wheel back with only the holes drilled for your existing studs, these will not work.
