Will this work on 03' gs300? So it basically direct bolt on and i can mount like an ls460 rims? Does it affect the ride quality or alignment in anyway? If not, i will get this from you
won't be able to use this with OEM LS460 wheels, the hub bore is tooo big as LS460 are 5x120 but still have the standard toyota 60.1mm hub bore size.
what size MM is this? i have a set of 5x120 wheels im looking at but really depends on the MM size adapter to determine the proper fitment. let me know
03 aristo, like I said on pm.....they will fit and mount up on your hub and sit hb centric to your gs....bore on adapter is 78 so it is slightly bigger than your 60.1 on the LS460......they will still fit though....just not hub centric...
rings are availabe...I believe they run 20 a piece.
25mm
if the bore on the adapter (the male portion that protrudes) is bigger than 60.1mm the wheel won't even fit on the adapter....
