NY FS: McGard Wheel locks set of 4
hey guys im selling 1 set of McGard wheel locks 24137. brand new but the packaging is a little discolored but has no effect to the locks themselves. im looking for
$17 shipped
![](http://www.mcgard.com/prod_imgs/LockConeReg.jpg)
![](http://www.mcgard.com/prod_imgs/Key5.jpg)
Wheel Locks
* Cone Seat
* M12x1.5 thread size
* 3/4" hex size
* 4 Locks w/ 1 Key
McGard’s easy to use, one-piece wheel lock functions like a regular lug nut, but requires a special key tool for installation and removal. Its design allows for an unlimited number of different computer generated lock and key patterns. McGard Locks are made right here in the United States to meet or exceed O.E.M. standards for safety and durability.
1. 8 different hex key sizes
McGard is the only manufacturer to offer 8 different key hex sizes to match the vehicle’s original equipment lug wrench. You will appreciate this important feature when you have to change a flat tire along the roadside.
2. User friendly keys
Our steel collar guides the key into the lock pattern. Simply place the key over the lock and turn until the patterns engage. The collar holds the key in alignment for easy installation and removal.
3. Computer generated extra narrow groove key patterns
The computer generated key designs allow for an infinite number of key patterns. The narrow groove resists the intrusion of lock removal tools into the pattern
4. The best chrome plating in the industry
The best in the industry. Our process includes three layers of nickel and one layer of microporous chrome. The first layer of nickel is for corrosion resistance; the second layer of nickel is for luster and the third nickel layer interacts with the microporous chrome layer to disperse nature’s corrosive action (rust).
5. Through-hardened steel construction
We use only restricted chemistry steel, made in the United States, specifically for McGard. These special standards insure the structural integrity of each and every fully machined McGard wheel lock. Every lock is through-hardened and tempered, reaching the depth of hardness needed for its unsurpassed level of security (unlike case hardening which is only a surface treatment).
6. Precision threads
Core integrity and precision machining provide the highest strength in the industry. All McGard locks and lug nuts meet or exceed the highest OEM proof load standards, 135,000 to 160,000 PSI.
7. Precise bearing surfaces
McGard’s standard for concentricity of the bearing surface to the pitch diameter is 30% more precise than OEM standards. This insures even distribution of the clamp load and uniform seating of the lock to the wheel.
$17 shipped
Wheel Locks
* Cone Seat
* 3/4" hex size
* 4 Locks w/ 1 Key
