i been eyeing these.. the sunken supra wheels are getting to be an eyesore.. 15 or 18mm in front, 5 mm in back should be sufficient.. ant, Ill text you if ya if i come up with the funds to get these..
i thought about buying these a while back..they were recommended to me by a friend..he had em on his SC and never had issues..the oem lugnuts probably wont work huh? unless u use like 20mm?
oem lug nuts to bolt down the spacer? or to bolt the wheel? im sure itll work on the wheel cause i used them on my oem wheels before. some lexus has the short open end lug nut cause they run center caps.
