CA FS: Work Equips 19x9.5+19, 19x11+25
Yes I could, but the wheels still will not clear the BBK that I have. If i was to buy just the outer lip then or just the inner barrel, it would not be as wide as I want them to be, and I would still need to run spacers. I would need to buy both front and rear barrels to change the offsets, and still need to run spacers to clear the brakes. That is just not very cost effective, and that's even if I could find the right barrels.
Thanks, but I'm looking for something wider in the rear and lower offsets in the front.
I'm not sure what you would need to do to make them fit on a IS300. I never really worked with a IS300. I'm sure with some work you can make these fit on any car.
Thanks for your input. The wheels are on the conservative side, but the fact that the fronts will not clear BBK makes them a little harder to fit depending on the car you put these on. It sounds like it should fit a GS without many problems.
So gangster, free Bump for you.
BTW might have some good luck selling these on 350z forums (www.my350z.com)
