VA FS: Vossen VVSO83 Flat BLK – 22x9 & 22x10.5 [Vouched]]
Vossen VVSO83 Wheels newly painted flat black.
22x9 (front)
22x10.5 (rear)
I had been running VEREDESTEIN tires - 245/30-22 & 295/25-22 and will include a used front and rear tire that only have 1,900 miles on them. No scratches or dents on the rims.
All four rims and two tires – asking $2,200.00 - local pick up and inspection - price reduced 1,450.00
PM or email me for faster response kleingr@gmail.com
Located in Northern VA
I can throw in all 4 TPMS sensors for an additional 100.00
The only reason I’m selling is because I’m not using the car enough and we decided to sell it. It was a lexus LS 460L.
2008 Lexus LS-460 Specs
Bolt Pattern: 5x120 | Center Bore: 60.1 | Hardware:14x1.50 Lug | Offset: 20-25mm
LS Year/Model: 2008 LS460L
Wheel Brand: Vossen
Wheel Model: VVS-083
Wheel Size Front: 22X9
Wheel Size Rear: 22X10.5
Wheel Finish: flat black
Lip size front (if applicable): 2"
Lip size rear (if applicable): 3”"
Lip finish (if applicable):
Offset Front: 31mm
Offset Rear: 31mm
Hub Bore size (if known): 60.1
Hub Centric Rings Required? notsure
Tire Size Front: 245/30-22
Tire Size Rear: 295/25-22
Tire Make/Model: Veredestein
Tire Air Pressure Preference: 40psi
22x9 (front)
22x10.5 (rear)
Wheel Brand: Vossen
Offset Front: 31mm
Offset Rear: 31mm
