Scratched TWO TONE Vossen CV3 20x10 +30 & 20x10.5 +25 with Tires $1600
Trying this again.
Location: Cleveland, TX Specs:20x10 +45 (comes with H&R 15mm spacers with extended bolts if you need it) & 20x10.5 +25 CV3's on 225/30/20 achilles and 255/30/20 achilles Price: $1600 not including shipping nor paypal 3% fee Condition: There are scuffs and scratches all over my painted wheels. You will need to repaint or sand down. There are also some curb rashes on the front wheels but nothing that sanding can't fix. Below are pics of blemishes.
Depends how low you go. But if very minor drop then you'll need to roll all 4 fenders.
Also the pics don't do the scratches justice, you need to really consider painting these or powder coating them.
can the front fit without the spacer on 350 brake caliper? what size tires do you run on those? thanks
On a IS250/350, no you must have a +32 or lower offset if running a 10"wide wheel in order to clear front arms.
225-30-20 tires only because I like a REALLY lowered suspension, static and didn't want to rub.
Yes they will clear the brakes.
It doesn't matter if they clear brakes though, you won't be able to do a full u turn without hitting the suspension arms unless you get a wheel that has correct offset or a spacer, like I got.
