TX LS460 OEM 18" Chrome wheels + Tires - Houston, TX
For Sale:
Set of (4) OEM Lexus LS460 18" Factory Chrome wheels & tires - Asking $675.00 OBO picked up in Houston, TX SOLD
-18 x 7.5" +32MM offset
-5 x 120 lug pattern
-In great condition with normal wear and tear from use; No peeling chrome
-1 Wheel has a slight rash *pictured*
-1 Wheel has a small nick *pictured*
-All wheels are straight and true
-Includes OEM Center caps; NO TPMS Sensors are installed or included!
Tires:
-All 4 are matching Michelin HXMXM4 tires in 235/50/18
(2) Tires are at 8.5/32 out of 9.5/32
(2) Tires are at 9.0/32 out of 9.5/32
As you can see from the tread depths, these are literally barely used.
All tires have even wear and do not have any holes, plugs, or patches.
Pictures:
![](https://lh5.googleusercontent.com/-wugoWXNV04M/VL7bv_EHTKI/AAAAAAAAKEM/mE7axQyux2I/w1262-h842-no/IMG_1739.JPG)
Wheel 1
![](https://lh5.googleusercontent.com/-a3xi7c6t43E/VL7bwcpFgZI/AAAAAAAAKEo/iRT2Y32qrB0/w1262-h842-no/IMG_1740.JPG)
Wheel 2
![](https://lh5.googleusercontent.com/-ayUfQrAC5H8/VL7bxUIR_eI/AAAAAAAAKEk/tQ3yfplpOB4/w1262-h842-no/IMG_1742.JPG)
Wheel 3 (with light rash)
![](https://lh6.googleusercontent.com/-U6TmglbGoOY/VL7bx8mwoTI/AAAAAAAAKFA/NkCwNBColr0/w1262-h842-no/IMG_1743.JPG)
![](https://lh5.googleusercontent.com/-U-nnt-SlU7M/VL7byROtOMI/AAAAAAAAKEw/1g2e-PL-AHM/w1262-h842-no/IMG_1744.JPG)
Wheel 4 (with small nick)
![](https://lh6.googleusercontent.com/-jTUwJhWF6i8/VL7byxgovSI/AAAAAAAAKE8/5jNwyH_GSyQ/w1262-h842-no/IMG_1745.JPG)
![](https://lh6.googleusercontent.com/-Wwgnfy7czJo/VL7bzZSUZEI/AAAAAAAAKFE/2jx6M_f6S5w/w1262-h842-no/IMG_1746.JPG)
Tires
![](https://lh3.googleusercontent.com/-2alO_NfsDgU/VL7bzoRYUpI/AAAAAAAAKFM/hsaALCxr9os/w1262-h842-no/IMG_1747.JPG)
Tires:
Pictures:
Wheel 1
Wheel 2
Tires
I am in Houston, and will just need to confirm if these will fit on a 2003 GS430. It currently has 245-45-R18 tires, but need to know if the offset will be a problem. Any advise would be appreciated.
The lug pattern is 5x120 and is not directly compatible with your GS. I believe the GS is 5x114.3. They do sell spacers that will convert the lug pattern to fit if you really wanted the wheels.
Offset on the wheels are +32mm.
Just a hunch but I don't see anything alarming about a +32mm offset on your GS. I believe the OEM offset on the GS is +45mm for an 18x8" wheel. So if anything it'll bring the wheel out 13mm closer to the fender. However you will have to factor in the spacer thickness if you want to go that direction as well. Just an option.
jdmek998
Wheels and Tires Classifieds
01-15-16 02:28 AM
ISFjimmy
10-04-13 03:24 PM
projectdna
15
10-04-10 04:21 PM
