275/35/19 SO-3s forsale
BRIDGESTONE
Potenza SO-3 Pole Position Tires
The tire size is 275/35/19.
Asking $425 + shipping
These were used for 1500 miles on my GS before being removed for a different set of wheels.
The tires are in excellent condition.
These tires are $255 each plus shipping at the Tire Rack.
Here is a description of the tires from Tire Rack.
The Potenza S-03 Pole Position is a Max Performance "summer" tire that was developed to meet the needs of the drivers of high performance sports cars, coupes and sedans by bringing Bridgestone's F1 tire technology and design to the streets while blending dry and wet traction without abandoning comfort and wear. The Potenza S-03 Pole Position features Bridgestone's UNI-T AQ II Technology that uses advanced compound and construction features to enhance and preserve wet traction through the tire's life. The Potenza S-03 Pole Position provides max performance that lasts.
On the outside, the Potenza S-03 Pole Position molds a Super Long Link Carbon Black, Dual Layer Tread II compound into a directional tread design that features notched shoulders, large "High Nose" intermediate tread blocks (that are shaped like the side view of a "high nose" F1 car) and a continuous center rib to provide quick dry road response and handling. Super Slant 3D grooves help direct and evacuate water through the tire to resist hydroplaning. The continuous center rib also helps reduce noise while providing constant road contact to enhance straight-line stability. Internally, the Potenza S-03 Pole Position features Bridgestone's Computer Optimized Component System which blends twin steel belts with spiral-wrapped Jointless Cap & Layer Construction which stabilize the tread area to enhance handling, high-speed capability and ride quality while minimizing weight.
Bridgestone Potenza S-03 Pole Position tires combine black sidewall styling with Bridgestone's F1 "High Nose" graphic and subtle black letters reversed out of circumferential serrations.
Originally posted by Letsride
Terry do you know if these will fit on an 8" wheel?
doesn't look like it....
according to manufacturing specs...
rim size = 9-11"
Originally posted by dartdoc1
Used tires shouldn't be this high in price because apparently you don't or didn't like them W/ my firestone discount a new set of 18's w/ lifetime balancing and rotation will run me approx. $826.00 it's good to have family member's retired from firestone, tires will be on by spring
WTF?
if you want to know why i am selling these, is because i'm sponsored now.
since you have your firestone discount.... why even bother posting to my thread?
dart
give the brother a break , dont disrupt his thread/posting with useless info like that , its great you have the discount , but that does us no good unless you are offering to extend the privl to us
terry is respected and a cl vet, we all know the worth of his deal, okay dude ,bro please chill out man
sockfocks
Wheels, Tires & Brakes Forum
12
08-21-07 02:43 PM
