Wheel compatibility between older RX and new NX
I am soon to say farewell to my beloved 2010 RX450h and replace it with a 2023 NX350. I have a 2nd set of alloy wheels I bought from a Toyota dealer for the purpose of me easily doing seasonal tire changes. I don't know much about them except they are not OEM, but dealer said they match OEM and they do ride perfectly well and I'm wondering if they will be compatible with my new NX. I don't know much about bolt patterns (other than to know there are 5), offsets, and whatever other wheel jargon that might be part of the picture. I use the same original lugs on both rims. My RX came with P235/55R19 and the NX will come with P235/50R20. I ran them thru an online tire calculator and they are extremely close in width and diameter. Should I expect to be able to use this second set of wheels from my RX on my coming NX without issue?
I'm thinking the TPMS sensors will probably not be compatible though, but not sure about this as well...
235/55R19 101V 7.5JJx19 ET35 on the 2010
235/50R20 100V 7.5Jx20 ET35 on the 2023
Looks pretty close with off set, actually exactly the same...
bolt pattern is the same and centre bore too. I would be comfortable putting those on if it was my car.
