How to add 2nd set of TPMS sensores
4th Gear
Hello all, lots of posts on this topic without any actual instructions or references to where this can be done in the manual. I have a 2023 Lexus NX and I have just mounted winter tyres with a set of 3party TPM sensors - how exactly do I add a second set of sensors? The Tyre place said they activated the sensors but my tyre pressure light is still on. I have been through the car menu a thousand times and cannot find where to add a second set. I have googled this to death as well with no luck other than having these specialised programming tools. Can you do it yourself without additional hardware? If so how? step by step process of reference site/video/page in the manual.
thanks
thanks
thanks
thanks
https://www.dillvalves.com/wp-content/uploads/TPMS-PDFs/Relearns/RL-A1255-2.pdf
4th Gear
Thanks
So this is the standard process but not specific to adding a second set for my NX. The tyre place did redo the procedure and they are now saved but as the default set so I assume when I put the summer tyres back on going to have the same problem.
QUOTE=lexo98;11639988]Depending on their verbiage activating the sensors may not relearn them to your vehicle. You can take a look at this though.
https://www.dillvalves.com/wp-conten...RL-A1255-2.pdf[/QUOTE]
