You like lips??? What HRE wheels are these?
Bob, what is the maximum size lip (front and back) you can do on these wheels for a GS4 keeping in mind a high disk fitment for big brakes and with slight fender modding (not drastic fender modding). - and what width rims?
My 3.5" rear lip is aggressive- I actually cut the rear fenders and had to shave about 1/4" (6mm) off of the rear axle stub to gain necessary clearance to install the center caps (I knew this when I spec'd them).
I also think the Porsche can accept an 11 inch wheel out back. With a high disk fittiment/proper offset for our cars,
BTW, Peter's car has TechArt body kit, exhaust, and coilovers. The car was displayed as a feature vehicle at this years' SEMA show. He can be contacted at : peter@wheelexperts for more info.
GSTRANCE, you're amazing.
Hameed - you can't get that agressive on a front lip if you want to fit big brakes. I was looking at GSTRANCE's beautiful Zauber Gettins with a big front lip and there's no chance he can fit my brakes.
![Agreed](https://www.clublexus.com/forums/images/smilies/boink.gif)
Originally posted by SoCalSC4
In February, I am converting my 20x10 841Rs to 20x11 so I can run 305/25-20 Pirelli P-Zero Nero (I am getting one of the first sets, with accompanying 255/30-20 front tires). The GS cars will take it, with proper offset!! Sweet!
![EEK!](https://www.clublexus.com/forums/images/smilies/eek.gif)
EV ftw!!!
Hameed, this is a 2" front / 3.5" rear lip set-up, same that my GS has. Generaly, we do a 2" front / 3" rear lip for customers with GSs, and they clear big brake kits easily, and I can run the rear offset up to about +43 which should require no fender mods.
Let me know what would be the maximum width of rim I could put in the back with minimal fender modifications keeping in mind that I will be using the stock brakes.
TIA!
EV ftw!!!
Originally posted by Hameed
Bob, so the maximum lip size would be 2" for the front to clear big brakes and 3" for the rear even though I will not be putting big brakes in the rear? Big brakes in the rear are mainly for show as the fronts usually do 80% of the braking, so I would not be upgrading the rears to big brakes.
TIA!
TIA!
2" in the front is no problem at all for big brakes. to me that's good enough
Holy S$$$!! What kind of fender mods would you have to do to accomodate those widths???
Bob, will those 20x11's go on without any additional fender mods?
The rear 3" lip is driven mostly by the clearance necessary to have the center cap fit over the protruding axle shaft. Depending on the rear kit, I can make a determination of whether or not the spoke will clear the caliper. In your case, it is a non-issue with the OE brakes. FYI, I use the OE rear brakes, too (with X-drilled rotors, pads, and stainless lines) because I couldn't justify the expense of the 14" rear StopTech kit primarily for looks- we agree!
he's most likely just going to push the extra 1" inward. say he has an offset of +35 in the back, that's with the 20x10. if he gets 20x11 and want to stay flush outside, maybe he will have to go with offset +60?
actually it depends on the design. with the 540r and the 840r design, with the right offset, the rims will clear big brakes no problem, including brembo and ap racing
-Bob
Hameed, the front lip is somewhat less noticeable when you have the high disc big brake clearing spokes though because they bow out and then back into the center.
I've got these on order for my SC400. I'll post when they are on the car. Then the debate can rage whether they belong only on that big bad beautiful Porsche!
ap0718
Wheels, Tires & Brakes Forum
23
09-13-23 03:48 AM
