IS300 offset and fitment, will it work?
I know this is going to get moved, which I dont understand. So hopefully some of you will reply first.
What is the max size of a rim that will fit on the IS? Max tires? I have 19x9.5 rears and 19x8.5 or 9 fronts. Also, the offset? will +45 work? They are originally from a Supra TT, Racing Hart C5's....any help would be appreciated.
if u have 9.5 rears, you need a +55mm offset and you can probably go as wide as 245 or 255 without fender modification... with mods, u can go from 255-275.. but 275 might require pulling the fender out...
on the fronts... i wouldn't go wider than 8... with either a 225 or 235 at max and a +42 or higher...+44..etc..
hope this helps...
these aren't facts but it gives a good ballpark. i in no way will be held responsible for anything not fitting due to this post.
hope this helps...
