offset question
thinkin about buying this racing hart m5 Front wheels are +44 OS 19x8. Tires are Michelin Pilot Sport 225/40/19 Rear wheels are +51 OS 19x8.5. Tires are Michelin Pilot Sport 255/35/19...do u think it will clear the rotora big brake kit? ohh yeah i have 01 gs300 dropped about 3 inches .... thanks jimmy
i don't know... i need another set of wheel cuz i want to get a big brake system and can't leave the hre on the winter time..and my stock 16in wont fit..damn so the offset is too low..ohh well keep on keep for a cheap used set....thanks jimmy
The wheels are going to sit inside the wheel well. It depends on the look you want. I think the seller of those wheels had pictures of them on an SC. The GS has similar offsets. A +44 will work if you dont mind not having too much lip.
Master Thread Closer!!
I agree with D....these wheel offsets match perfectly for an IS300.
If you got them for your GS....it will sit inside the wheel well for sure.
As for rubbing....its hard to tell if it'll rub against your calipers without seeing the wheel spoke design. With this offset, you should also be concern that it'll rub the control arm.
RC5
RC F (2015-present)
23
04-19-19 05:24 AM
