S03's driving me INSANE!!!!!!!!
Loves Snickerdoodles!
I couldn't be more happy with my S03's
I used to run on Yoks before and they're definitely a big improvement over them. As far as road noise is concerned.
-Seize
-Seize
Originally posted by Letsride
Well the noise of the SO3 is still more acceptable than the Kuhmo's....
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Originally posted by Neo
How many miles do you have on your S03s? Just curious since they seem to start out OK then gets louder as it wears down.
-Seize
GSTRANCE:
What air pressure are you running your S03? I notice that when the air pressure drops below my normal setting the tire gets quite noisy especially when braking. When I increase the pressure the noise level decreases. I am currently running 40psi (front) and 38psi (rear).
Chu...
Chu...
GS -Trance
Originally posted by ChuH
GSTRANCE:
Chu...
GSTRANCE:
Chu...
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Originally posted by Kajukenbo
I don't have any problem with So3 as well. I have about 6000 miles on them.
You do need to make sure that you have eough air in them. 40psi is a pretty good number.
GS -Trance
kaju and Dave,
thanks.I cant believe you guys dont have noise on yours and I have sooooo much though.I am gonna try 40psi in there tomm. and see.Are you guys doing 40psi front and back tires?
