"92 Lexus LS400" Will i be able to put 20x9.5" Rims all around? Whats the widest rim?
WIll I be able to put 20x9.5 on my 92 LS 400? Whats the widest rim I will be able to fit on my LS400?
Former Sponsor
PM a member named Lonely Toothbrush, he is running a 20x9.5" Brabus wheel all the way around on his LS400, he can probably tell you what needs to be done. He is running 245/255/35-20 tires I think.
Former Sponsor
Originally posted by buttons
I couldn't imagine what 35% tire would ride like-probably like a 'solid' tire !!
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
The 35 aspect ratio would give a harsher ride, but thats the tradeoff for better handling!!
20x9.5 +40 with 255-35-20 in the rear.
Originally posted by Lonely Toothbrush
20x9.5 +44 with 245-35-20 in the front.
Ps.. Is it possible to get at least a 2" lip all the way around with the offset you listed? What offset should use to have a real deep dish without rubbing.
Thanks Alot!!
Thanks for the reply. I have another question... Will i have to shave the fenders ("so it won't rub the tires")? Did you lower your car any? If you did how low did you lower it?
Thanks Alot!!
Thanks Alot!!
If you want 2-inch lip in the front, go with 20x8.5 +30~+35 Low-Disk (depends on what kind of wheel u're getting.) Or 20x9 +34~38 Low-Disk.....But u can only run 245-35-20 in the front.
In the back, u can run 20x10 +36~44 Super Low Disk and you'll get about 3~4 inch lip.
My LS is lower 1 1/4 inches with my rear wheelwells trimmed off. The front fits ok.
Is it the lower the offset, the wider the lip?
The lower the offset, the wheels stick out more therefore you'll get bigger lips. BUT there is an offset/ wheel width limit for every car unless you can do the wide body set up.
Thanks Alot
Thanks for the help.. So the lowest offset for 20x9 on an LS400 is +34... Can I put plus 34 all the way around without any problems.
Thanks Alot
Thanks Alot
