19x8 on the front (GS400)??
HI Can I use 19x8 rims on the front for a GS400? and 19x9.5 in the rear?
whats is the WIDEST wheel i can put on a 19x8?
the wheels are VOLK SF WINNING. Please help..
Thanks!!!
Thanks!!!
Originally posted by rominl
well there is no reason why you can NOT do that, though 8.5 would be more ideal
just make sure offset is right
on 8", 235 is good
on 8", 235 is good
and the offset is in the 40s for sure.. so i should be ok right?
I wouldve gotten the 8.5 but this was a deal of a lifetime.
4 volk racing SF winning (19x8) and 4 tires for $900USD!!!
no way of putting 245s on these wheels?
The One
Originally posted by bluelex
.5 inch doesn't seem like a lot of when on the car i'm sure it shows it...
and neo, 245 on 8 is fine
thanks guys.. so just to confirm... a 245/35or40/19 tire should be totally ok on a 19x8 rim correct..?
The tire is not gonna come off the wheel when making a hard turn will it? thats my major concern.. =)
The One
Originally posted by chrisleX
for a similar gs400 with 1.5" drop ( bilstein springs/stock shocks) and 19x8.5 with 245/35/19 on all 4 corners, do you need any spacer ? thx.
but to answer your question, if you have 8.5 at 4 corners that fit well and no rubbing, that means the wheels in the back will be more inset (suck in) compared to the front. that's why i always prefer staggered setup. if you want to look better, put spacers in the back. but spacers are never good for handling
RanGer498
Wheels, Tires & Brakes Forum
04-23-04 11:18 PM
