19" and GS400
Originally posted by chrisleX
ok, thx a lot guys - my last q - will these 19" X 9" - 35HSS with 245/40/19 fit ALL 4 CORNERS without any rubbing ?
ok, but what about 245/35/19 with 19 x 9 and 35 offset ? i don't want 19 x 8 and 235 tire, they will look like the stock 235 ! i want fatter in front - 245 ! thx rominl again !
i'm planning to go for the L-TUNED - shocks/springs - so ~ 1" drop ! i want the 19x9 front but i don't want any rubbing issues and i want to be sure about this before ordering the package ! thx.
i've finally decided - FRONT - 19 x 8 offset + 38 with 245 / 35 / 19, REAR - 19 x 9 offset + 35 with 275 / 30 / 19 ( on tirerack they have this possiblity 245 on 19x8 and 275 on 19x9 ). i hope this setup will work w/o any rubbing, maybe our master of setups rominl will aprove ! thx.
on the setup, it will work as in terms of width and offset, though they definitely are very conservative. that's equivalent to 8.5 front 42 and 10 rear 47, compared to what i call optimal 8.5 front 35-38 and 10 rear 42-44. you be the judge
but it will look much better than stock, especially after installing the L-TUNED suspension (springs/shocks) !
at least i'm happy that i can fit 245 on 19x8 front and 275 on 19x9 rear !!!
Now, how can i calculate the new speed value, considering i'll have 2 setups - front and rear ! is there any formula that uses front and rear values ?
oh of course it's a lot better man! and the tires will fit, though it's not perfect too, it will work.
speed? that's spec tires so your speedo is good, no need to worry about that
