tire size
the IS comes with 215/45/17 on 7" wide wheels. The SportCross has 225/45's on the rear and uses a 7.5" rear wheel. Going to a 235 would require an even wider wheel because 5mm is about 1/4 inch and you want to go 10mm. The 235's will fit the stock 7" rim but the center of the tire will be pushed up like the edge of a donut. It is hard on the tire, not safe to drive on and will wear quickly. Do it right and get the proper width wheels.
thank you for that info, the only reason y i ask and for the who are interested there is a set of 2 for sale in the wheel forum for $100 shipped with less then 500miles on them
Originally posted by SCryder
will 235/45ZR17's fit the IS rim which is 215/45/17(i think)
