285/30/19 with a 19x9.5 +42 offset
Will 285/30/19 tires with a 19x9.5 +42 offset wheel fit a GS4 rear without rubbing?
Car will be lowered to 1 finger gap.
ROMINl ? anyone? please help.
Originally posted by Lonely Toothbrush
Hey rominl, I'm planning to run 20x9 +36 in the front, 20x10 +24 in the rear on the GS430. Do you think that's doable?
for the front it's also aggressive. for 9 i don't suggest more than 38, i have 8.5 +32 and it's the same as 9 +38 and i know it's very close already, i rub now and then and i already have mod to the fender. so with 9 +36 you might rub more. but then again if you do the super vip look with bad camber that's no problem
my 2 cents though
Originally posted by jucee187
the reason i ask is b/c 285/30/19 is the almost EXACT same height as 245/35/19.
more compatible.
more compatible.
you mean the stock 17s sidewall height? its 105.75mm..
Doesnt airtrackk have 285/30/19s in the rear??
Im running 245-35-20 with +36 offset and 285-30-20 with +47 ofsett with no rubbing whatsoever even with riding 3 adults in the back and mind you I also have the Ltuned susp.
