offset question on fat 19 setup
Old 03-19-04, 08:35 PM
sliver2JZ
sliver2JZ's Avatar
Default offset question on fat 19 setup
I can get a good deal on a set of 19x10's for the rear but they have a +22 offset
Will these rims fit and if not could anything be done to adapt the rims to fit?
thanks for any help
Michael
Old 03-19-04, 09:08 PM
TopSCecreT
TopSCecreT's Avatar
wow, +22? that offset is too extreme......you'll need fender flares to make those fit.....i got 19x10s with +44 on mine.....
Old 03-19-04, 09:12 PM
rominl
exclusive matchup
rominl's Avatar
22? man, good luck, i won't go that far
Old 03-19-04, 10:56 PM
GS4Will
GS4Will's Avatar
waaayy too much on the offset
Old 03-20-04, 02:04 PM
kutscher
kutscher's Avatar
This offset discussion always confuses me.
the numbers are always opposite of what my intuition tells me.
Is there an easy way to think of these numbers. If I am right the number represents the distance between the mounting surface and the center of the wheel. Is this right??
Thanks for helping with my continual confusion!
Old 03-20-04, 06:35 PM
rominl
exclusive matchup
rominl's Avatar
well it's just coz' you have a bad idea about offset. the higher the offset, the inner the wheel is. the lower, the outer. that's the basics
iamkhanz
07-07-07 06:47 AM
lexman2006
03-22-06 11:35 AM
c33w
05-03-04 12:05 PM
Blackmarket
04-05-04 05:46 PM
Quick Reply: offset question on fat 19 setup
