Bolt pattern for gs400
Huh? What bolt(s)?
If it's the wheel lugs, you want to put them on in a star pattern. You will want to hand tighten them the same way to ensure that it's properly centered on the hub. Then when all 5 lug are set by hand, you can get a torque wrench and tighten the lug bolts to 76 ft-lbs. in the same star pattern.
Don't undertorque your nuts, or they'll come loose. Dont overtorque them or you can eventually cause your rotors to warp prematurely from the uneven pressure.
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
RanGer, I've moved your post to the wheels and tires forum where questions like this go ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Did you try to search for this info using keywords 'bolt pattern GS400' or something similar? bet you could find the answer right away!
Forum Administrator
Yep, bunch of threads that have it sitting right there... try it sometime
Here are a couple
https://www.clublexus.com/forums/sho...+pattern+gs400
