The real story on 20's on the IS300
exclusive matchup
Originally posted by SoCalSC4
You could use the new Pirelli NERO 245/30-20 front and 285/25-20 rear, but this will require major fender mods in the rear and a 'perfect' offset. For this set-up, you'd want to go 20x8.5 front & 20x10 rear.
Also, Nitto has a new 20" tire out for 'sport compact' cars. If I recall, it's 225/30-20. I think BFG has one this size, too.
This would work well on the IS, but there is no matching (wider) rear tire to go with it.
You "might" be able to put 20's on in the front, but you'd never be able to drop your car.
Unless you got some 20x7 up front and a 215 tire on a high offset like a 49.
But is it worth it? running 19's will give you pretty much no tire as it is. With 20's it'll be a rubber band.
You can fit 20's in the back. 20x10 is pushing it. Ideally you want to go 45-48 offset up front and in back.
exclusive matchup
