will the 350z or g35 wheels...
exclusive matchup
Re: Re: Re: Re: Re: Re: Re: will the 350z or g35 wheels...
Originally posted by SexySC
G35c stock 18's offset is 32, will that fit the GS ?
Anyway, 1Sick will scream DO NOT PUT INFINITI WHEELS ON A LEXUS !!!
I run a 19x10 rear with a +35 offset. I am able to tuck the rear rim and tire when drop my car all the way down. keep in mind my tire spec is 235-35-19... My fenders ARE NOT rolled at all..
If you want to run something like a +25 offset you will need to run a stretched tire like mine or something less aggressive like a 245-35-19 on the rear. Of course, Lonely Toothbrush is right, you might need to cut the inner lip of your fender off to prevent some rubbing....
what offset do you have in the front
Originally posted by UptownGS
you can fit 235's on a 19x10" wheel??? I was scared to move down to 255's from my 19x9.5
Guest
Posts: n/a
Why would u put a Tag band on a Rolex? I am lost here. Looking at the offsets being asked, they are not even close without some serious work being done or you won't be driving the car, for show only.
Kajukenbo
Wheels, Tires & Brakes Forum
12-21-01 03:05 PM
