Max/Min Wheel Offset (ET)-04 LS
Old 07-14-04, 09:07 AM
eblue
eblue's Avatar
Default Max/Min Wheel Offset (ET)-04 LS
Does anybody know the max / min allowed wheel offset for the 04 ls430? I'm thinking of buying 35mm when the OEM specs seem to require 45mm on 7.5 widths(i'm thinking of buying 8 Front and 9 Rear).
Old 07-14-04, 06:14 PM
shrabber
shrabber's Avatar
DONT KNOW BUT THE 20 X 8.5 IOVANNAS WILL NOT FIT U NEED TO BE REAL CAREFUL IN THE BACK ANYTHING WILL WORK I HAVE A 2004 LS 430 AND THE FRONT WHEELS SLAM THE CALIPERS
Old 07-16-04, 09:02 AM
jpcdmd
jpcdmd's Avatar
don't buy wheels with a 35 mm offset. I bought four 20x8.5 Kaotic wheels for my 2001 and their offset is 34mm. I have a lot of tire noise in the front only in tight turns and there is a little steering kickback. No problem with the rears. A little change in offset like that really plays with the front suspension feel. I will actually be looking to replace the wheels soon with a staggered setup with the proper offset in the front, 43-45mm. Not to mention, I had to grind the outside of the front calipers to clear the inside of the wheels because they were not "high disk" wheels. I'm also getting a suspension clunk when I go over a speed bump, I don't know if that has anything to do with the wheels wearing out the suspension parts prematurely. Stick with the proper offset.
Old 07-16-04, 12:33 PM
J.P.
J.P.'s Avatar
Default Re: Max/Min Wheel Offset (ET)-04 LS
Make sure you get a high disc wheel and you will be fine!!!!!!!!!!!!!!! The problem noted from shrabber is because the giovanna wheel is not a high disc wheel..........
Old 07-16-04, 05:07 PM
shrabber
shrabber's Avatar
right IF YOUR GUYS KNOW OF ANY 20 INCH NICE CHROME RIMS THAT WILL FIT A 2004 LEXUS PROPERLY SHOOT ME SOME INFO THANKS TIM
Old 07-16-04, 06:02 PM
J.P.
J.P.'s Avatar
Work Wheels
Rays
SSR
Old 07-17-04, 04:29 PM
shrabber
shrabber's Avatar
HERES MY CAR WITH 20 INCH RIMS IF ANY ONE KNOWS OF A GLASSY CHROME 20 INCH SHOWING A 5 BOLT PATTERN PLEASE ADVISE ME THANKS TIM
Attached Thumbnails Max/Min Wheel Offset (ET)-04 LS-picture-001.jpg
Old 07-18-04, 10:59 AM
J.P.
J.P.'s Avatar
I cannot understand how you put that on an LS 430!!!!
Look at the
Work LS
Zauber Gettin
SSR Vienna Courage
There is 213213 high disk wheels out there in 5 star.
Old 07-18-04, 11:03 AM
J.P.
J.P.'s Avatar
Manaray catalog scan
These come in high disk and they are top quality wheels. Look how sweet an LS can look.
Attached Thumbnails Max/Min Wheel Offset (ET)-04 LS-spoke3ls430.jpg
Old 07-18-04, 03:20 PM
shrabber
shrabber's Avatar
dude wtf do you say these are cheap there perfect fit if you want to critisize wheres your car????????
Old 07-18-04, 05:03 PM
shrabber
shrabber's Avatar
THOSE ARE NICE RIMS THOUGH BUT MAGIZINES MAKES HINGS ALOT NICER AND HAAZ NEEPERS ARE NOT CHEAP RIMS
Old 07-18-04, 05:05 PM
shrabber
shrabber's Avatar
OHY ONE MORE THING DO SOME RESEARCH THERE DISCONTINUED IN USA
Old 07-19-04, 09:02 AM
J.P.
J.P.'s Avatar
Take a guess at how many people have JDM wheels here............ Just because you cannot walk into 7-11 and get them, doesn't mean they cannot be had in the US.
And many of the CL members cars look as good, if not better then some of the mags.
Old 07-19-04, 09:19 AM
J.P.
J.P.'s Avatar
I didn’t say they are cheap, they are just not my style. Also, they are not a perfect fit as you noted, since in several threads you were “warning” people about your caliper scraping the rim because you didn’t get a high disk wheel.
If you like how your car looks, that is all that matters.
Old 07-19-04, 03:37 PM
shrabber
shrabber's Avatar
NO THE HAAZ NEEPERS ARE A PERFECT FIT DONT HIT CALIPERS I AM BUYING A NEW SET TO REPLACE THEM I HAD THEM ON A 2002 GS AND NOW THE 2004 BUT I WOULD LIKE A CLASSIER CHANGE MONEY ISNT A OBJECT FOR QUALITY IF YOU CAN POINT ME TOO A WEBSITE THAT CAN HELP ME FIND A CLASSY RIM IT WILL BE APPRECIATED THANKS TIM
Quick Reply: Max/Min Wheel Offset (ET)-04 LS
