offset question on aftermarket wheels for a gs300
19x9 35 offset (front)
19x10 40 offset (rear)
1" drop all around
will these stick out? what is the best size tires for fronts and rear. i know the drop is not aggressive but i have to carry people around.
thanks
1" drop all around
thanks
exclusive matchup
Re: offset question on aftermarket wheels for a gs300
1" drop all around
thanks
1" drop all around
thanks
front very aggressive, imho that's too much to take and you will rub pretty bad unless you do some quite serious mod to the fender. the rear is also very aggressive, you have to shave the fender for sure
tires? 245 and 275 would be what i suggest to avoid even more rubbing (even with fender mod). whether you go fat setup or not that's your call. with fat setup you will rub more as well
