Sidewall strength matters but has no measurements.
Old 08-04-04, 03:58 PM
siniquezu
siniquezu's Avatar
Default Sidewall strength matters but has no measurements.
I had a set of Micheline pilots 275/30 tires to mount on my 19s, but two tire places couldn't mount it even with 4 guys at it! I went to America's Tires and another local tires shop. Apparently, the sidewall was too strong to push down on the wheel and there was no flex. However, the second tire shop was able to easily mount the S03s because of the flex on the sidewalls. So now I *HAVE* to have s03s despite the horror stories. So my question is:
Is there a measurement for sidewall flex?
Old 08-04-04, 04:17 PM
legendary
legendary's Avatar
that is a good question...are you putting them on 9.5 " or 10 " wheels?
Old 08-04-04, 04:24 PM
siniquezu
siniquezu's Avatar
They went on 10" wide wheels.
Old 08-04-04, 09:04 PM
rominl
exclusive matchup
rominl's Avatar
i don't think there is measurement, it's a matter of design. they have thick sidewall for strength, etc...
i would try a better shop
Old 08-05-04, 10:32 AM
AutoCoutureSC
AutoCoutureSC's Avatar
thang, PM me or call. I know a place where you can get it done. it shouldn't be a problem at all. HOpefully those guys at America's Tires didn't scratch your rims.
Old 08-05-04, 11:58 AM
pureshot
pureshot's Avatar
Where those Michelin Pilot PS2 or an old model? I wonder if you would have had the same problem with 275/35/19 as its a wider sidewall.
I was considering the PS2 as its reported to be a softer ride?
Old 08-05-04, 02:51 PM
Brandon@TR
Former Sponsor
Brandon@TR's Avatar
Default Sidewall
A rough gauge of the sidewall stiffness of the tire is the speed rating. Also tires with very low profiles many times have reinforced sidewalls because the volume of air is so low. Many places will have a hard time with ultra low profile 19 and 20 inch sizes it's important to find a place that can handle the job.
JaeISF
06-23-17 04:10 AM
candyeg
13
11-12-12 12:02 AM
WillyD
Pacific
05-19-11 12:56 PM
Vegassc400
03-29-03 02:47 PM
david2u
12-16-02 09:35 AM
Quick Reply: Sidewall strength matters but has no measurements.
