Need Advice: Tires Squeal
Hello all again,
I feel like i'm always asking questions and never contributing anything substantial =). But here we are again...with more questions.... Actually, I'm afraid my question might be retarded, but I couldn't find anything using the almighty "SEARCH"..so..here we go....
I was wondering if there is anything I can do to reduce the amount of tire squeal when I take turns in the ES. Can it be my tire pressure and i need to fix that? I just recently has my 45,000 inspection from the dealer themselves and everything checked out okay (according to them), so I'm thinking its not that. Switch tires from OEM? New suspension? Sway bars? Or just a good ole smack upside the head and the following "Stop taking turns so hard"?
On a side note, I do realize I *may* take turns a little too hard, and at times, I feel the ES is jumpy...sometimes where I'm like *woah* on the rear (almost feels like the rear would *swing out* from under me). Is there something I can do about that? Or again with the good ole smack upside the head and the following "Stop taking turns so hard"? =)
I know the ES is not meant for performance/handling like a GS or IS, but still....
any thoughts?
hopefully besides
any thoughts?
hopefully besides
Originally posted by tonytony
dang it!
hmm...softer compound? How do I know what to look for?
dang it!
Wouldn't a strut tower bar help keep his car tracking better in turns and then reduce the tire squeal as well?
I also thought that less air will give better traction. I always air my truck down when Off-Roading. It not only provides a smoother ride, but adds a lot of traction.
Thanks for all the replies. I will try my best to answer this...
As for my current tires, I think I have V rated rated tires., specifically, Michelin MXV4-A Plus 205/60R16 91V is what it says on the sidewall. Alignment is perfect, my other cars that I've driven has pretty bad alignment so I *know*, I can let go of the wheel going 20-30mph and it will go straight on itself for a bit. I just recently had my 45K thing with my dealership, and I remember that the tires are actually NOT wearing evenly, just off by a bit i want to say. I think i want to say my rear right is wearing more so than any other tires, with my front right next worst. I can be more sure..but i have to pull documentation. Finally, tire pressue, I have no idea....I wouldn't even have the stuff to check the psi.
VTEC?? How would having a VTEC engine help me?
Could be worn out tires. I remember my truck tires squeeling because they were about gone. You could get a softer compound, but you in return you give up tire life. Sounds like you drive pretty hard. If you bought a softer tire, your tires will go out pretty quick. That jump in the car you feel is when your tires are holding as much grip as possible. You probably hit some sort of bump in the pavement and it loses grip. I love that feeling. Its fun to kick the back end sideways, something fwd dont do often. Since your car is fwd and tends to "push", your front tires are wearing a lot faster than your rear.
That's pretty well worn down. I think MXV4's have about 10/32" tread depth new. I also have a set of MXV4 Plus's ( with about 6/32" remaining), and they do chirp from time to time when cornering.
I agree those tires are almost worn down to be determined as unsafe for driving. If the tread depth reaches less than 2/32" (or below the top edge of Abe's head from the penny test), the tires need to be replaced ASAP. Since you're really close to that critical tread depth, you mind as well think about replacing all of the tires now. Do you have any thoughts on your tire purchase?
Don't worry about the VTEC comment. That's a pointless comment that should have been deleted.
Thanks for the replies, so you all thinking but replacing the tires it would help me with my grip issues?
I was thinking about the thread and thinking that its kinda down, but I was waiting until my new rims came in and then wrap some 18"s on it. I definitly want to get new tires for my OEM wheels since I wouldn't be riding my 18s in the winter time. i'm thinking about getting 16s that would be great for winter yet at the same time be okay enough for me to roll in during the summer time for emergency purposes if I blow a tire or something with my 18s. Would the Michelin Pilot XGTH4 or V4's do that for me?
About the VTEC..yeah..i read up on that..and I figured it was a joke or something.
