What do you guys think about these Volk Wheels??
Hey guys,
Found these nice looking Volk Racing wheels. Specs are :
Front 18X8.5 offset 32mm
Rear 18x9.5 offset 43mm
114.3X5 bolt pattern
They are asking $1400, do you think i should get it for my sc300 and do i need a spacer to ft them on my car.
All opinions welcome.
Thanks.
Thanks.
![](http://www.pbase.com/mongoldrifter/image/34717067.jpg)
![](http://www.pbase.com/mongoldrifter/image/34717140.jpg)
Originally posted by Carisma FR
The wheels look good. The front will sit nice under the fender. The rear can use a 5-10mm spacers to push the wheels out a little more.
i see a clean black sc rolling around on those exact wheels everynow and then....they look nice!
CEO
CEO
i like the volk gt-u a little better but those wheels do look hot
http://www.mackinindustries.com/rays_gt-u.html
Correct me if I'm wrong..32 offset is a bit aggressive for the front...You might have rubbing issues if your running on a 245 sized tire...235 sized tire might do the trick...
You can run a 5mm spacer in the back...But, if your going to use a 275 series tire, then there is really no need...
I've seen these actual set of wheels in Chatsworth, Ca @ Takumi Project.
The lips will need a bit of re-polishing.....
as well as the face of all the wheels.....
In those pics, they appear perfect, but in person - they aren't so.....
Thanks for all your input guys, after seeing so many positive feedback on it, ill buy them tomorrow. My car is not lowered yet, when i bought it, it came with KYB shocks and stock springs i believe, car sits high, but i do plan to buy HKS coilovers. Where can i purchase the wheels spacers (really good ones), any help is appreciated guys.
What size tire do you guys recommend then?
Front 235/40/18's???
Rear 255/35/18's???
Thanks guys.
They are Volk Evolution 3.
Rear 255/35/18's???
Thanks guys.
Rear 255/35/18's???
Thanks guys.
Rear 255/35/18's???
Thanks guys.
And for the rear tires, I go with 265's depending if you can fit them or not - wider is better
Volk Evo 3's are old school, and are becoming really rare......
** 32mm offset is pushing the tire out towards the fender...
As Onehott mentioned you may have rubbing issues
I can attest that 245 on the front may rub since I am close and running a 35mm offset up front.
---- Just changed headlights and had to turn the tires side to side to access the fender wells and really noticed that I am closssssseee to rubbing... any less offset may not work with a drop..
Just would hate to see you have tire issues after purchasing these rims...
