thoughts on these wheels
What do u guys think about the ASA wheels that are on tire rack? Specifically models RT8, ST2 & ST3.
RT8 Specs
Size Selected: 20x8.5
Wheel Offset: +42mm
Weight: 38.6 lbs.
ST3 Specs
Size Selected: 19x8.5
Wheel Offset: +42mm
Weight: 30.4 lbs.
ST2 Specs
Wheel Offset: +42mm
Weight: 31.3 lbs.
Would you recommend these wheels, or should I look into a different brand?
Thanks fellas
RT8 Specs
Wheel Offset: +42mm
Weight: 38.6 lbs.
ST3 Specs
Wheel Offset: +42mm
Weight: 30.4 lbs.
ST2 Specs
Wheel Offset: +42mm
Weight: 31.3 lbs.
Thanks fellas
Guest
Posts: n/a
RT8 Specs
Wheel Offset: +42mm
Weight: 38.6 lbs.
ST3 Specs
Wheel Offset: +42mm
Weight: 30.4 lbs.
ST2 Specs
Wheel Offset: +42mm
Weight: 31.3 lbs.
Thanks fellas
RT8 Specs
Wheel Offset: +42mm
Weight: 38.6 lbs.
ST3 Specs
Wheel Offset: +42mm
Weight: 30.4 lbs.
ST2 Specs
Wheel Offset: +42mm
Weight: 31.3 lbs.
Thanks fellas
to be honest, i want curb appeal. I want a set of wheels that'll make u look at the car twice. I'm just unsure of what brand I should go with. As far as size goes, 19s or 20s is what I'm looking for. I'm thinking more of a 5 spoke. Something similar to the stock look.
Later
Later
Later
Later
Benjamin T
Wheels, Tires & Brakes Forum
12
07-16-07 05:27 PM
hiyabrad
01-26-03 10:35 AM
