Silly Question
Hello,
I was looking at buying Some AutoCouture rims.
They are:
Rim Size Front: 18 x 8.5
Offset Front: +37 Hi 73mm Bore
Rim Size Rear: 18 x 10
Offset Rear: +42 Lo 73mm Bore
Lug Pattern: 5 x 114.3
Will these rims fit my 2001 gs300. Is the offfset ok?
Someone who knows this stuff, please let me know.
Thank-you
David
They are:
Thank-you
David
Originally Posted by dwoods420
Hello,
They are:
Thank-you
David
They are:
Thank-you
David
i believe lexus bore is 62
https://www.clublexus.com/forums/sho...d.php?t=115165
it will fit no problem. you will need hub centric rings of course, which is pretty common on jdm wheels i believe
about the bore, i am not 100% but i thought it's 60.2, but i could be wrong on this one
dwoods420
Wheels, Tires & Brakes Forum
03-10-05 10:46 AM
XenonES3
07-17-03 07:19 AM
