need your help!! will these rims fit a gs400/430???
need your help ASAP!! will these rims fit a gs400/430???
SSR GT3 19x8.5 +30 offset fronts and 19x10.5 +43 offset rears.
will these fit a gs400/430 (2nd gen) correctly???? will they stick out too far from the fenders??? im more concerned about the 10.5 inch rear wheels with that offset. thanks.
x10.5, ready to roll your fenders. Are you looking at the set off from G35C or 350Z? If off from M3, forget about it, wrong bolt pattern
I've got 20x10.5 +41 with 285/30-20
This works well if you shave the fender a bit. If you run 275/30-19 on the 19x10.5 +43, it should stretch the tire enough to clear the fender- you'll need to remove the rear fender arch trim (four phillips head screws).
The front is aggressive- a 245/35-19 might occasionally touch the plastic fender liner over big dips.
exclusive matchup
Dan@FSM
GS - 1st Gen (1993-1997)
07-23-08 09:03 AM
