255/ 40R-17s will they rub?
Hi everyone,
I had the misfortune of getting in the way of a rolling object and blew our one of my tires. To make matters worse, Michelin discontinued the model I have, so I'm looking at replacing all four.
I've place an order for the BFG G-Force T/As in 255/ 40-R17s as they are not available in the stock size. I know the height to be almost an exact match to the 235/45R-17s but I'm a little concerned about rubbing, as the new size is almost 3/4 of an inch wider.
I know we've beat tire sizes to death on this forum, but I've rarely come across any information regarding the upsizing of the stock 17s on stock suspensions!
Also, does anyone know how these tires compare with the Michelin Pilot Sports? More noise, less noise, handling etc.
ok
heres the deal
OEM lexus rims are 17x8
tire manufacturers all agree that the widest you can SAFELY go without worrying about the tire stretching off the rim on an 8" wide wheel is 255
I wouldn't go 265 on OEM rims, but by all means if you are running 17x9's 265 is more than fine
heres the deal
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
Originally Posted by NT2SHBBY
ok
heres the deal
heres the deal
ChuckB planted the seed in my head of doing Iforged 17".
Would be lighter than OEM
If I did that I could go 9" wide on the rear.
So you don't think there would be any rubbing with that size.
I've been thinking about going wider in the rear since I got the TC.
Kind of think more tire on the road would help traction.
But I'm not really feeling the urge to get bigger wheels.
Feel free to make comments
Thanks
Ivan
3dog
Originally Posted by 3dog
Hey thanks
Thanks
Ivan
3dog
Thanks
Ivan
3dog
If I can go 265/40/18 w/o rubbing 265/40/17 would be fine, but IMO I would step it up to 265/45/17 (depending upon how low you are now)
I am on eibachs and I know I wouldnt rub
when I had thoughts of getting 18's (before I bent a set of factory 17's
) I was gonna go 245/45/18 up front and 265/40/18 out back
If the PP2 came in a 275-40-17 or 275-45-17 I would even think about going that wide.
Thanks for the feedback
Ivan
3dog
What would be the benefit of 265-45 over 265-40. I'm only about .5" lower than stock.
Ivan
3dog
Ivan
3dog
I like the safety of added cushion to the wheel (I live in NYC) plus the ride will be better
golddot
06-29-23 11:20 AM
RocketGuy3
Wheels, Tires & Brakes Forum
08-12-09 04:26 PM
