18s with fat tire setup --- Will they fit?
Will these fit a 2003 GS430 w/ l-tuned suspension, with out doing any body mod? Is there even a chance that they might rub? https://www.clublexus.com/forums/sho...d.php?t=145333
Thanks much.
Thanks much.
The One
The front tires will rub a little when turning and backing up. With +37 front and +42 rear, they are nice offsets for the GS, not too aggressive and not too conservative. With the fronts, it is just something you have to put up with since the wheel diameter is about 1" larger than spec.
My cousin has a set of Momos (not sure on offsets since he did not ask me about issues before getting it
) running the 18s "faaaat" setup with no lowering. He rubs in the cases I mentioned too.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
The One
Originally Posted by IS0LD0UT
How about with a 245/40 F And 275/35 R. Still issues?
As far as the wheels, the only rubbing that MIGHT happen is if you are REALLY lowered and on dips, you'll hit the top of the wheel liner plastic. With the L-Tuned, though, you will be fine.
EyeKutr
10-09-07 06:09 AM
