Getting wheel spacers for GS
Im looking to get wheel spacers for the rear wheels. The specs of the wheels are 18x8.5 with +40 offset. Can i run 25mm spacers with my setup without rubbing the fender?
Since 25mm is about 1inch, this would be the same as me having a 18x9.5 with +40 offset.
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Since 25mm is about 1inch, this would be the same as me having a 18x9.5 with +40 offset.![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Hey my friend ! Putting a 25mm spacer in the rear with a +40 offset will leave u with a +15 offset !!
what tire dimensions do u have?
best bet go with 15mm .. are u going tohave your car slammed? I have a +33 offset in the rear with the fender completely shaved off on a 275 tire.
D-MAN63,
Whats up bro......my wheels are 18x8.5 and im running 245/40/18 tires.
Main reason i wanted to get the 25mm ones because they are much easier to install.
D-MAN63,
15, and 20mm spacers install the same way, all comes with longer studs.
yeah 15mm and 25mm they should be the same deal.
8.5 +40, with 25mm that's 8.5 +15. if convert that to 10, it would add 18, so it's 33. that's pretty off, even shaving the whole fender lip won't work. if you put 15mm instead, that's like 10 +43. that would put you right on the fender without doing any fender mod
now if you wanna do reasonable fender mod and get a bit more aggressive, get 20mm, that's like 10 +38, that's just like what neo has
