HP Design EVO: hyper silver dark rims?
Found these on ebay and wondering if they are a good fit for my car..They are 18x8 and 18x9 but i want all 18x8 so i can rotate them easier...They have a 38 offset.. Is 38 stock for our car?
How would these look on a pearl white Gs? I think they would look good.. but the car is not lowered so it might look really stupid.... Any ideas and thoughts...Thanks Tony
Originally Posted by Neo
These will fit fine, a little conservative but still better than stock. OEM is 17x8 +50.
Lower is ideal but ultimately it's your car.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
The One
The HPs will be closer to the fender. They both will fit your car.
Here are a few threads to look at:
http://www.yokohamatire.com/utcustom.asp
https://www.clublexus.com/forums/sho...d.php?t=137458
https://www.clublexus.com/forums/sho...d.php?t=115250
https://www.clublexus.com/forums/sho...d.php?t=113849
Let me know if you still have questions.
The One
Originally Posted by tmf2004
Neo, what do you mean by closer to the fender? So i guess the lower the offset the better? is that what you meant by lower is ideal...Thanks tony
If you wnat that aggressive look, then yes, lower offsets are better. There comes a point, however, that you will be too far outside the fender.
As for the lower comment, it was an answer to your question about lowering.
Pretend you are taking your wheels off. You are moving it along the hub. A lower offset moves your wheels along that axis more towards the fender.
Neo for all your help... Can you give me a a rough offset range i should stay in between...example: betwwen 35 to 50 or something like that.. Also what tire size would you reccommend to get with 19's? Thanks tony
The One
If you are planning no fender mods, you can do the following range:
19x8: +32 - +50 (OEM)
19x8.5: + 38 - +50 (probably a little higher but why?
The more you are in the lower range, the more flushed with the fender you will be. This is for the front. The rear has more room but since you are not doing staggered, you are limited by the front fitment.
hung8852
10-25-06 12:27 PM
