gs wheel Q?
Old 06-30-05, 03:13 PM
xBlkGs430x
xBlkGs430x's Avatar
Default gs wheel Q?
im looking to get a set of rims w/ 5X114.3 bolt pattern with 32 mm offset, the car is a gs430 w/ 2" drop. will these rims fit it?
Old 06-30-05, 03:27 PM
sockfocks
sockfocks's Avatar
you need more info than just the bolt pattern and offset. The width of the wheel plus offset spec will tell a lot about how the wheel will fit. Check the wheels and tires forum for GS fitment questions there is a sticky there. Plus there are lots of knowledgeable people on this forum. https://www.clublexus.com/forums/sho...d.php?t=115165
Old 06-30-05, 04:13 PM
blacksc400
Car Chat Moderator
blacksc400's Avatar
yes, more specs needed!!!
Old 06-30-05, 08:55 PM
xBlkGs430x
xBlkGs430x's Avatar
they are 19"X8.5 will i need to use wheel spacers? and will i have to roll the fenders
Old 06-30-05, 09:48 PM
Neo
The One
Neo's Avatar
The rear won't be a problem. The front will need a little fender management but nothing too drastic. A little bending and rolling should be all that is needed.
Old 07-03-05, 08:56 PM
xBlkGs430x
xBlkGs430x's Avatar
im looking at a different wheel, but the bolt pattern is 5x112 will i be able to use an adapter to make them fit, if its possible.
Fronts 20x8.5 +32 offset
Rears 20x9.5 +35 offset
gpmillar31
08-12-16 10:47 PM
ba2sy
01-19-16 05:19 PM
wmb0000
03-19-10 10:28 AM
Escobar
21
06-13-05 06:22 PM
CSHFLW
08-17-01 01:19 PM
Quick Reply: gs wheel Q?
