Need help with new Tires
Old 07-18-05, 04:47 PM
CinFulxgs
CinFulxgs's Avatar
Exclamation Need help with new Tires
Mods can you leave this here just for a little while... I am hoping to order these tonight...
I plan on getting new tires from the rack tonight for my new Salina's...
Should I go with the factory spec size or a little taller sidewall to improve comfort?
Anyone with size recomendations would be appreciated.
Factory sizes are...
Fronts - 235/40/18
Rears - 265/35/18
I plan on getting the BFGoodrich g-Force Sport which recieved good reviews for tread life, low noise, and wet/dry traction from most reviews on the site... This is mainly a price decision but nice to see that in this case few $$$ buy a decent tire.
Also, can anyone confirm if the lug on the left in the picture in this thread is the factory lug and not something L-Tuned and special...
https://www.clublexus.com/forums/sho...26#post1405726
Old 07-18-05, 05:46 PM
blacksc400
Car Chat Moderator
blacksc400's Avatar
Nice choice on the tires, the size look OK to me.
You should use the factory lug nuts cause from the look of the wheels I think I need them to hold it tight.
Hope you will like your setup!
Old 07-18-05, 05:54 PM
rheiy
rheiy's Avatar
The ideal setup for 18's is 245/40 front and 275/35 rear. I'm assuming your salina's in the rear are at least 9" wide. If not, your better off with 235 or 245 on all four rims if they are 8 or 8.5
Old 07-18-05, 06:02 PM
CinFulxgs
CinFulxgs's Avatar
Actually I believe the fronts are 8 and the rears are 9.5
Old 07-18-05, 06:52 PM
chuckb
chuckb's Avatar
you know about this, right? http://www.miata.net/garage/tirecalcold.html
I have 245-40-18 Pirelli Pzero neros and they are comfy. I know your rears are bigger so according to my calculations, 275-35 rear and 235 40 front are your best bet. that way, the rear tire is only .1 of an inch taller than front
Old 07-18-05, 07:14 PM
CinFulxgs
CinFulxgs's Avatar
Thanks for the feedback... i think i am just going to pull the trigger and do the factory sizes.
Old 07-18-05, 07:32 PM
rheiy
rheiy's Avatar
Actually, the 235/40 is 25.4 where as the 245/40 is 25.7 and 275/35 is 25.6. The stock tires for the
gs are 225/55/16 which is 25.7. That's why a 245/40 and 275/35 in 18's are the ideal setup
Old 07-18-05, 07:35 PM
rheiy
rheiy's Avatar
My rear's are 9.5 and the 275/35 fits great..
Old 07-18-05, 07:49 PM
chuckb
chuckb's Avatar
the only thing I don't like about that setup is the front tire is .1 TALLER than rear. I don't know if that is even an issue, but you'd think you'd want it the other way around
Old 07-18-05, 08:22 PM
Neo
The One
Neo's Avatar
You know what my vote is.
Old 07-18-05, 08:28 PM
CinFulxgs
CinFulxgs's Avatar
What about these sizes as compared to stock?
Tire Size Comparison
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
Stock - 225/55-16 4.9in 12.9in 25.7in 80.9in 783 0.0%
Front - 245/40-18 3.9in 12.9in 25.7in 80.8in 784 -0.1%
Rear - 285/35-18 3.9in 12.9in 25.9in 81.2in 780 0.4%
Diameter is now .2 inches taller instead of .1 shorter in rear?
However, doesn't the L-Tuned drop compensate for the .1 inch difference... I thought the official drop was 1 inch front and .9 rear for the L-Tuned shock/spring combo?
Factory L-Tuned sizes were...
Front - 235/40-18 3.7in 12.7in 25.4in 79.8in 794 -1.3%
Rear - 265/35-18 3.7in 12.7in 25.3in 79.5in 797 -1.7%
Note the rear diameter off by that .1 inch...
So maybe the 245/40-18 275/35-18 setup does make the most sense!
Old 07-18-05, 08:33 PM
CinFulxgs
CinFulxgs's Avatar
Thanks Mods for letting this stay up in the main forum for a little while... I still want a little more input by tomorrow before I put in the order 4 these...
Old 07-18-05, 08:34 PM
Neo
The One
Neo's Avatar
I personally like the 245/285 combo but I would not recommend it for daily driving/family usage unless you had at least an 8.5/10 staggered combo.
Old 07-18-05, 08:52 PM
CinFulxgs
CinFulxgs's Avatar
I don't get it? Why not?
And what is your vote? The sizes you were going to go with?
Old 07-19-05, 01:36 AM
Neo
The One
Neo's Avatar
Because the width of the rims and the width of the tires are not optimal for a 8/9.5 245/285 setup. I know there are guys that push the limits even more and that's fine. I just personally would not do it, especially since the car is my daily and I take my family all over in it.
With wider rims (8.5/10), the tires will be more within the tolerance.
And yes, for the Salinas, my vote would be 245/275. If you are worried that it is not OEM, the GS340 Sport edition that is available in Europe comes with the Salinas and they run 245/275. This is a Lexus edition and not an "aftermarket" edition like L-Tuned/TRD.
Quick Reply: Need help with new Tires
