whats better ...size and off set question
Originally Posted by GTFM
im asking from a fender Modding situation
i rather not roll fenders and what not thanks
but still want nice lps
edit- and by the way, both of those sizes sound VERY conservative for the GS-
Originally Posted by rominl
both are the same outboard, so you are asking the same question ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
you need to mod the fender a bit i say, just some slight rolling and you are good
i have 20x8.5 +32, imagine that![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
i have 20x9 on front with a 37 offset and did not have to mod at all,,,,,,,,,,,,if i were you i would definately get the 19x9 and get the bigger lip,,,,,,,,,as far as your question goes there is 25.4 mm in an inch so if the wheel is 1/2" wider that means it is 1/4" more on each side,,,,,,,,,,,,1/4" more sticking out is only 6.35mm,,,,,,,,,,,,so therefore if your 8.5" wide wheel is 6mm less agressive in essence by doing the 19x9 you are only going to be sitting out .35 mm more than the 8.5" wide wheel,,,,,,,,,,,,,,,hope this makes sense, the way i worded it may or may not be understood, trust me though from a rim and tire seller, do the 19x9, you will be happy you did and the 19x9 is only gonna stick out .35 mm more than the 8.5,,,,,,you cant even hardly see .35 mm
The One
As far as the choice between the two, I'd take the x9. With how far it sticks out, the two specs are basically the same. Why not just go for the wider which will probably give you a little more lip? IF thereare fender mods to be made, you'd have to do the same with either setup. The only concern with wider is inside clearance but with those specs, you should be fine.
The One
Originally Posted by Blue98Gs3
I'm a bit confused on how I can run a 20x8.5 inch wheel up front with a +35 offset and clear the fender with no modding what so ever?
The One
Originally Posted by sc400texas
From my understanding, GS's can run more aggressive offsets than SCs, and Im running a 9.5 with an offset under 35 in the rear with no rolling and some camber.
Maybe I assumed too much, but when GTFM asked about those sizes and I know his car, I was pretty sure he was not asking for his rear.
Originally Posted by Neo
This is in the rear. The GS can definitely handle x9.5 +35 in the rear. All the "turning" problems have to do with the front.
Maybe I assumed too much, but when GTFM asked about those sizes and I know his car, I was pretty sure he was not asking for his rear.![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
ahh... I see, I see.
The One
actually, my only question is, is 9 +41 too inboard? i know 9 +38 will fit no problem (with 245). i am just not sure about 9 +41. if it can fit, that's good news
It will be close.
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
